Need help adding some power to my pig
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chev4life, Jan 24, 2005.
  1. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    As stated, my 87 is a pig...great offroad cause of the 700r4, but bad onroad cause of no power, heavy tires, etc...see sig for more info. I have throley headers, and will be throwing on a magnaflow muffler in place of my rusted flowmaster soon but I need more power. The engine has 135k on it and runs really good except my 10mpg :D, do you think it is worth throwing a little money into to get it going better? I was thinking the Edelbrock EFI systems since I can slap it on a newer small block later down the road...any opinions on this? Was also thinking of doing the RV cam...mild a little more power and I dont want to touch my heads. I am in cali and need to be smog legal also.
    Thanks guys for any info you can send my way!
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Maybe one of those entry level GM crates. Even the lowest end model is pretty powerful, and you can throw your TBI on it
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
  4. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    I have thought about a crate, but with living in an apartment at present I dont have the space to swap a motor. Some day down the road I will drop one in. You know of good place to see what they offer? Who else makes good crate short blocks?
  5. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    1st thing I would do is start scanning and logging the ECM. This will tell you if there are any components that need replacing which are causing you power loss.
    How about starting with the basics and take it from there?
    Some basic things to do to a TBI motor are:
    1. Replace O2 sensor(s)
    2. install throttle body spacer
    3. K&N filter
    4. custom chip for the ECM
    The TBI should be plenty for a stock motor, not sure how much gains you would get from changing that out without doing any head/cam work.
    Thomas.
  6. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    I have replaced everything on the engine pretty much....
    fuel pump
    gas tank
    injectors
    o2 sensor
    egr
    temp sending units
    plugs
    plug wires
    distributor
    coil
    also have...
    throley headers, k&n intake, flowmaster, highflow cat
    I have thought about the spacer, but dont want to get it if I go mutliport...the rest I did because the truck was running like crap so I did the "replace everything I can get my hands on" rutine:grin:
    I just dont think I have enough power...I am way better than stock..but stock wasnt very good to start with and I drive hard. The tires and heavy 14bolt hurt in terms of excel...maybe could got to 4.56's over my 4.10's
  7. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Do you have the ability to scan the ECM? If not, I would recommend WinALDL for a free scanning solution.
    This will show you things like the mixture and BLMs along with any timing retard due to knock issues (maybe false knock due to the headers is causing a power loss?)
    Thomas.
  8. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Maybe step up to 4.56 gears. The 4.10s you have now are good for mileage but make it seem like you have less power with 35" tires.
  9. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Sweet, thanks for the link...I have been looking for something to scan. I havent noticed any running probs after the headers, but I will check it out.
  10. dyeager535
    26,982
    191
    You made sure to change the gears in the tranny to match the setup you are running now?
  11. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    PorQue?
    Change the gears in my tranny...why would I do that? The diff gears in combo w/ my tire size puts me a final drive slightly better (lower) than stock. No reason to tear into tranny.
