Need help as soon as possible... :(
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, May 5, 2001.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    Hey,
    I know, I'm and idiot, but hey whats new... [​IMG]
    I am replacing my distributor cap, rotor, wires, plugs, and coil... I was having a REAL hard time getting the new distributor cap mounted, and so I thought that my haynes manual would have the firing order...
    as a result I pulled all the wires off my old distributor and new with the assumption that I had all the info I needed in my trusty manual...
    as a result, I don't...
    Can somebody post a picture??? I also need to know the gap I should be using for the plugs...
    Thanks,
    <font color=blue> Jeff </font color=blue>
    [​IMG][​IMG]
  2. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Firing order should be 1-8-4-3-6-5-7-2. Odd number cylinders on the drivers side front towards the radiator start with #1,then 3,5,7 even number on the passenger side starting with #2,then 4,6,8.
    The only thing you have to know is where #1 on the cap is. When the timing mark is aligned with 0 degrees, the rotor should be pointing close to #1 or #6.
    Hope this helps.
    Sorry, I don't have a picture of this.
    Shawn
    87 K5
    few mods[​IMG]
    <A target="_blank" HREF=http://www.off-road.com/chevy>http://www.off-road.com/chevy</A>
  3. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    hey, thanks a ton for the info... fortunately I remember where number 2 was connected to the distributor so I think I can figure it out from here...
    Thanks again for the info...
    [​IMG][​IMG]
  4. Shawn
    1,753
    5
    5280'
    BTW-
    I'm pretty sure the gap should be .035. If you install a performance coil, you can usually gap the plugs at .045.
    Shawn
    87 K5
    few mods[​IMG]
  5. Grim-Reaper
    7,385
    Atlanta
    If you still have the stock intake manifold the firing order is cast into it in front of the carb/tbi where you can't ever loose it [​IMG] Should also be a tune up sticker on the core suport or breather that has the gap listed. If not most parts stores can look up the gap when they sell you the plugs. .35 does sound about right.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    hey, thanks for everbodies input... the firing order was correct, and I gapped the plugs at .40...
    put in an accell performance coil, cap, and rotor, tailor wires, and v plugs... man what a difference...
    I gonna put in a fireball ingition system before winter, but I wasn't ready go through all that now...
    I can't believe that my haynes manual didn't have the firing order, what a rip!!! [​IMG]
    [​IMG][​IMG]
  7. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    It's got it in there. It's in a weird place if I remember correctly. I can't locate mine at this present time.....I'll see if I can get you a page number.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
