need help asap- no start!
Discussion in 'The Garage' started by 79k20350, Mar 18, 2006.
  1. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    ok my 1990 jeep yj aint starting. yeah thats right i drive a heep for my dd. :crazy::rolleyes: anyways its a 258 w/ the carter 2b carb. i was down the road from my house on some trails and i shut the thing off a few mintues after running over a really big stump. it was running fine after i was over it. i went to start it back up and nothing. just a click. got a buddy to try and jump me, nothing. volt meter shows roughly 12 volts. everything works. i installed a new starter, cleaned all connections and still nothing. im not even sure the click is from the starter. maybe a relay? im at my wits end and need this to be running for monday:o any help is appreciated guys!
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    IIRC.....a fully charged battery should be over 13 volts.
  3. 79k20350
    Nov 22, 2004
    7,757
    Ct
    even so ive tried jumping it and using other batteries and still nothing.
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Tried a new starter and a different battery. Tried a remote starter switch yet, to see if it might be your ignition/starter switch (or the wiring thereto)?
  5. diesel4me
    Jul 24, 2003
    17,542
    936
    Massachussetts
    try...
    If you know how to,try jumping the solenoid ..that will tell you if the starter,solenoid,or the wiring is faulty...if it cranks when jumped,its probaby wiring or a blown fusible link not activating the solenoid..:crazy:
  6. wildmouse216
    wildmouse216 1/2 ton status
    Dec 26, 2005
    135
    Rifle, Colorado
    Did you check the ground or negative battery cable. Whenever I have starter problems this is what I check first.
  7. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    don't forget the start-run relay...
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    ok i got to go back down today and try some more stiff. i tried to jump the terminals but im not sure i had a good connection ill check the ground again. man this is making me go nuts:o
