Need Help Asap!! Steering Arm ???
Discussion in 'The Garage' started by gmcjimmy88, Jul 17, 2005.
  1. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    I got the arm removed from the top of the knuckle. How do the bolts come out to put the longer ones in? I tried hitting them with a hammer for a while but they did not move. Just figured I would see how other people got them out or if I need to take the front end apart and get them pressed out? Thanks for the help in advance
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    HEAT, HEAT and more HEAT
    You can also try welding a nut onto the studs so you can TRY to use a wrench on them....with HEAT of course.
  3. gmcjimmy88
    Feb 10, 2005
    559
    You have gotten these off before? Will I have enough room to get the new studs in there
  4. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Get a stud removing socket
  5. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    sears sales a stud tool for under 25 bucks. works with a 1/2 drive ratchet.
  6. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Double nut the studs. You just put 2 nuts on the stud and tighten them against each other, then turn the lower nut to loosen the stud.
  7. uglytruck
    uglytruck Registered Member
    May 9, 2005
    27
    Phoenix, Az
    Lots of penetrating oil let soak in for a day resoaking periodically. That looks just like the ones I took out for mine. They are tapered studs not threaded so it's just a matter of busting them loose. I used a two pound hammer and all the strength I could muster. Good luck, if that doesn't work try heating the metal around the base of the studs. :wink1:
