need help asap
Discussion in 'The Garage' started by gjk5, Jun 13, 2004.
  1. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Trying to change all the fluids and gaskets today, all is going well until I try to take the oil filter off. I try the big graphite nut, the steel strap oil filter wrench,and neither works, I get the biggest pipe wrench I can fine and voila, it mangles the oil filter into a nice greasy piece of origami. Any ideas how I can get this now ruined thing off? I've tried everything I know how, I would love to start the engine up and see if getting it warm might help, but not with a big gash in the filter.
    thanks.
  2. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    hey bud call me mabyei can help 640-7742
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have had some problems like that before on a couple vehicles, including my last Chevelle. Had to take a screwdriver on one and hammer it into filter, and then tapped and turned it off, did make a mess. Another time I used a punch and hammered it off slowly, made a mess there too . An old timer once said use a leather belt and turn it off as the leather will grab the mangled part and grip it as you pull/tighten it /forums/images/graemlins/k5.gif
  4. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    What Paul said. All the old timers where I came from -- tractor country -- told me exactly that... the belt trick, or the BFS (big ... screwdriver) thing.
    -- A
  5. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    he got it loose or should i say his neighbor got it /forums/images/graemlins/thumb.gif
  6. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    when all else fails, pound a big scewdriver through the filter and then turn it like a big handle, I do it quite often. cause some (darn) gorilla,(me) turned it too tight when he installed it, /forums/images/graemlins/waytogo.gif
  7. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Tried the big screwdriver thing, just mangled it. Ultimately the neighbor's superior knowledge of leverage and the use of a few choice words worked it on loose. /forums/images/graemlins/rotfl.gif Good ol' Dan. Anyway, I've chewed up a few filters, but this one was nasty when we were done with it. thanks for the pointers.
  8. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    If you tear the can right off with the screwdriver trick--its time for the heavy artillery--remove the "can" down to the base until you get to the plate that threads onto the motor,youll see several holes around its circumfrence--you can use a punch and 5lb hammer to "spin" the plate off--you can use an air chisel to advantage here too(carefully)to get the remains off--.
    You have my sympathy--seems every time I change the oil on one of my "new" purchases,some gorilla put the filter on,and never changed it for 5 years! /forums/images/graemlins/angryfire.gif
