Need Help Asap
Discussion in 'The Garage' started by coptezr, May 14, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    Im putting a 1 inch ord body lift in and where are 2 back body bolts i cat figure where there at.
    thanks ryan
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Go to the very rear of the frame. If you lift the carpet in the bed, you will see the two bolts. Now go underneath the frame, you will see two holes on the bottom of the frame, the nuts are up in there. You may need a flashlight to see them, but stick your socket up there and feel around, you'll find them.
  3. coptezr
    Jan 13, 2005
    342
    now what about the 2 that are behind the doors they dont want to seem to come out.
  4. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    The bolts????????????????????
    Get a couple of cans of PB Blaster, makes life easier...........
    If you are talking about the body mounts themselves, soak the thing in PB Blaster and just stick a screwdriver in between the rubber and the mounting cup and just mess with it, it'll come out.............
  5. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Actually you can't just spray PB blaster on the cab mount bolts. They are captive nuts inside a the cab mounts which you can't access. And to top it off they have yellow loc-tite on them, at least mine did. What you can do though is drill a 1/8 inch hole in the cab mounts so you can stick the small red tube that comes with the PB blaster inside it and you can spray directly onto the nut.
  6. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    I have had good luck on those with a tourch, but I dont have great interior :confused:
  7. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    It'll get through there somehow, I just did it. :deal: :deal: :deal:
  8. coptezr
    Jan 13, 2005
    342
    yep i got it on now what do i do about the bumper gaps should i go get a sheet of diamond plate and but them to fit?
