Need Help Asap!!!!!!
Discussion in 'The Garage' started by Disciples Performance, Sep 30, 2006.
  1. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    hey guys ive run into a snag, just installed my new RPM Air Gap Intake on my blazer on propane now unfortunatly my throttle body is not a square bore :mad: so it doesnt work doesnt anybody know if i can take an old carter or holley base plate and bolt it up in place of my old throttle body????:confused:
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    They make an adapter to go from spreadbore to square bore. It is probably your best bet to do the swap right.
    Harley
  3. Disciples Performance
    Dec 6, 2005
    404
    Kelowna BC, Canada
    i have that adapter plate but the issue is that studs that u install the into the manifold in order to hold the baseplate down dont go through my throttle body since its a spreadbore throttle body....
  4. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    does your adapter have the dual bolt patterns? mine has a small pattern for squarebores and a wider pattern for spreadbores. it uses allen screws on the inside to bolt to the manifold and then standard bolts turned upside down that act as studs. the bottom side of the adapter has hex shaped holes to hold the bolts in place.
  5. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    Back in the 80's Mr. Gasket used to make a plate for that.
