NEED HELP ASAP!!!!
Discussion in 'The Garage' started by BIGDAN112686, Nov 11, 2003.
  1. BIGDAN112686
    BIGDAN112686 1/2 ton status
    Nov 20, 2002
    112
    nc
    alright, im doin the rear of my 4 inch lift. im havin a lot of trouble compressing the rear springs enough to fit them into the places they need to be. anyone with some ideas please post up as soon as you can. ill try almost anything.
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    First thing that comes to mind...
    Do you have the correct length springs?
    ->52" or 56" Blazers are 52"
    Is the shackle moved into the correct position to line up properly?
    To be honest, it's kinda a vague description of the problem. Elaborate and we'll see if we can help. /forums/images/graemlins/smile.gif
    John
  3. BIGDAN112686
    Nov 20, 2002
    112
    nc
    yes, they are the correct size, 52". the shakles are lined up best possible, but it just wont compress to fit to where i can put a bolt through, does that make sense?
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Which end did you bolt-up first?
    I always do the forward mount first, then attach the shackle to the hanger.....the final assembly is the rear spring eye to the shackle and with a tall enough jack you can get it there.....
  5. BIGDAN112686
    Nov 20, 2002
    112
    nc
    i have the 2.5 ton long frame jack. jacks like 33 inches or somethin. but i cant get either side to line up. am i making any sense?
  6. BIGDAN112686
    Nov 20, 2002
    112
    nc
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Are you installing a flip at the same time or just 2.5" rear springs to the stock hanger/shackle?
  8. BIGDAN112686
    Nov 20, 2002
    112
    nc
    im doin 4 inch springs only. i think that we might just drop the whole axle this weekend, might be a little easier.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    What i did when i replaced my rear springs a while ago, was lower the axle about 6" or so, bolt up the front spring eye, then bolt the shackle to the rear spring eye, the bolt the shackle to the hanger. I used the axle by raising and lowering it to get the spring to line up /forums/images/graemlins/thumb.gif
  10. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    What MuddyTazz says. /forums/images/graemlins/thumb.gif
  11. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    id use a pry bar, a center punch to line up the hole, and yes put in the front bolt first, because then you can screw with the rear shackle, i had to pry my shackle to the horizontal position before i got my bolt to go in my spring. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thinking.gif.
  12. BIGDAN112686
    Nov 20, 2002
    112
    nc
    thanks for all the info. it looks like im gonna have to drop the axle more than i was expecting, which i couldnt do today. one more week without it wont kill me. thakns again.
  13. stretch67
    stretch67 1/2 ton status
    Nov 1, 2003
    171
    bozeman mt
    you didn't mention if the rear axle was bolted to the springs before you tried to bolt springs up??? if it is you would have the problem you describe having. you need to have the springs without any load or tension on them it is easier to get the axle pads onto the spring center bolts with springs bolted up than springs bolted to axle first!! hope this helps /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
