Need help Badly...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Aug 26, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    After calling a bunch of dealers in Colorado, I have basically given up on them as a source of info...I spent 30 min. on the phone with Purifoy and came away with NOTHING...
    I am looking for the part numbers for the shifter bolt the holds the t-case shifter to the adapter on a 465/205 tranny/t-case adapter...Someone here posted a part number for that they used for their bolt...I ordered it and it is the wrong one... It was part number #14009313...I need the one that has the smaller diameter threded section...probably from an older (pre-'72, maybe)...
    So does anyone have the part number for t-case shifter bolt the has the smaller diameter threaded section...?
  2. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    I have a 205 out of an '86 K30 which has the big bolt, and a 205 out of my 71 Jimmy which has the small bolt. I believe the only difference is the nylon anti-rattle bushing which is installed in the shifter hole in the small-bolt application. If you can live without the bushing, you may be able to utilize the big bolt.
    Good luck
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I did this same thing. I ordered the greasable bolt. happy when I got it cause it was cheaper than it was posted on here. Well it's for the big bolt version...ughh..I need the small version too, is there a part number for a greasable small version (1/2"??) thought about having this one machined down to the size I need
  4. JungleBoy
    Jan 31, 2001
    243
    Houston TX
    If you guys can wait till this weekend maybe I can dig up the pre-72 part number out of my old 46-72 GM Truck parts catalog. That will give you a starting place at the parts counter, at least. Remind me by PM if I forget...
