need help....beginner
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by rasta_one, Jan 29, 2002.
  1. rasta_one
    rasta_one Registered Member
    Jan 16, 2002
    24
    fremont, california
    i have a 72 blazer. ive had it for about 3 years and havent really done nothing to it. i bought it really cheap and i want to start fixing it up and also learn how to fix it as well as what parts i have on it like transfer case, tranny, etc. anyways, one of my first questions is: my fronts are 6 lug and dont know what type of axle, my rears are 8 lug and dont know what type of axle. what do i need to do to make the fronts 8 lug. parts and etc. the reason is cuz i want to put some 38 meats on the beast. thanks for all the help and info in advance that is generated.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    First check out
    <a target="_blank" href=http://coloradok5.com/8lugconversion.shtml>8 Lug Conversion</a>
    and
    <a target="_blank" href=http://coloradok5.com/axleguide.shtml>Axle ID Chart</a>
    Most likely you have a stock front end which would be a Dana 44. You can either upgrade it to 8 Lug or swap in a Dana 60 (hard to find and $$$...but strong).
    Because you have a 72 I would guess you have a NP205 Transfer case and either a th350 (auto) or SM465(4 speed).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Were are you, fill out your profile.
    the 8 lugs in the rear is most likely a 14bolt or an old school Eaton rearend. Does the rear end cover look round or odd shaped?
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Rasta,
    Yes please fill out the profile.....it will help everyone who's trying to assist you! [​IMG]
    I'm in the same position as you....If got an 8-Lug 14Bolt for the rear, but I can't swap it in until I get the Dana 44 (the stock front axle for '72) up front converted to 8-Lug also.
    If you check the "For Sale" boards you can sometimes find someone selling the 8-Lug conversion parts.....you will typically need new Spindles, Hubs, Backing Plates and Rotors to complete the job. Usually you can get a set for around $200. That's a LOT cheaper than the alternative (Dana 60 axle = $1000 and up!!)
    Also, if you go to the '73 - '91 Board, do a keyword search on "8-Lug Conversion" and you should find a bunch of info.....anything written by ThatK30Guy is going to be useful.....that's Wes.....and as far as I'm concerned, he's a GOD when it comes to K5 technical information!!! [​IMG]
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  5. rasta_one
    Jan 16, 2002
    24
    fremont, california
    thanks for the info.....all very helpful.....hey greg72, im not that far from you.....may be we can learn to convert the 6 to 8 together.....
    if it aint chronic don't blaze it up.....and if it aint a chevy don't raise it up.....
  6. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Whats up rasta one! Welcome Dude!!!
    As far as the 8 lug rearend, you don't want it... It's probally uh, weaker. yeah. I have a six lug 12 bolt under my '72 K/5 right now.. what do ya say we trade? Then at least it will match the front! [​IMG][​IMG][​IMG]
    I'm not too far from you either... over here in san jose, campbell area. What color is your K/5? I've seen a few around. Is your Blazer your daily driver like mine?
    Oh yeah, nice signature. [insert red eyed smily[​IMG][​IMG]
    [Real Men Don't Care About Gas Mileage Or Rapid Tire Wear!]
    1972 K/5
    Ryan B.
