Need Help, Boy did I screw up
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerBoy, Aug 29, 2000.
  1. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I messed up guys, need a little help. While I was rebuilding my 350 motor, I messed up putting on the timing chain, I was off a few links, I got kinda confused with all of the stupid keyway slots, anyways. I tried starting it, and ended up bending most of my push rods, and quite a few of my valves. So now I am looking into getting new valves and redoing my heads, I wanted to have a 3 angle valve job anyways. Or just get new heads. I have an 87' with TBI I was wondering if pre 87' heads will bolt up, The reason I ask is I have a friend that has some nice aluminum pre 87' heads. I know mine are centerbolt style, is that the only differance?? Thanks guys..
    BlazerBoy
    http://generalblueballs.coloradok5.com
  2. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    The bolds of the intake manifold are under a different angel. I know their exists intake manifolds for TBI that fit on non TBI (pre `87) heads.
    Greetings from Amsterdam,
    River `90 K5, 350, TH700R4, NP241, "33, 3.08, 10 bolt F, 10 Bolt R
  3. BlazerBoy
    639
    Chicago IL.
    Now that you mention that, I recall hearing that the center 2 bolts are at a differant angle. I think that was it, Anyways I thought I heard of people redrilling these holes to fit. Is that not a good option? I have never seen it so I dont know how differant the angles are. Thanks
    BlazerBoy
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Hot Rod did this a while back. I tried this a while ago and eneded up srewing up my intake. It could probably be fixed, but I just went out a bought the right intake witht he different angle bolts. ou could probably take you intake to a engine machine shop and tell them you want the TBI manifold to fit on the old style heads and they will do a hell of a lot better job than me with my Craftsmen drill![​IMG]
    This will probably be cheaper than a new intake!
    My probelms was that after I drilled, I calculated wrong and my holes were oblonged and too big and cause an intake leak. The machine shop should be able to do it right!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  5. BlazerBoy
    639
    Chicago IL.
  6. BlazerBoy
    639
    Chicago IL.
  7. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    If it were me, I'd buy a set of cast-iron Vortec heads right from GM. Complete heads with valves and springs runs about $400 or so depending where you get them. They flow very well and work very well. You will gain close to as much HP/TQ as most un-ported AL heads, such as trick flows. But you might need to get a custom chip from Howell to get the best performance.
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  8. realsquash
    Jul 12, 2000
    778
    SE WI
    When you redrill the intake, the bolt heads will not sit correctly on the intake. Maybe there are angled washers made, but i still don't like it. The vortec heads will be a direct swap for your broken original heads. The valve covers and intake will fit right on.
    Squash
