Need help, Brakes aargh!
Discussion in 'The Garage' started by NewMexK5, Mar 6, 2006.
  1. NewMexK5
    NewMexK5 1/2 ton status
    Jul 25, 2002
    201
    Carlsbad, NM
    I have been searching through the threads on 14 disc brake swaps and keep finding conflicting information on what I need to get my stopping power back. I have seen in a few threads that all it takes is a different proportioning valve or possibly running two T's instead of a prop. valve to get even flow front and rear. Then I see in other threads that I need to replace the master cylinder or use one with two even reservoirs.
    If anyone can post up what they did and how there brakes are stopping that would be great. Cause at this point I am even contemplating just putting the drums back on.:screwy:
    Thanks,
    Tommy:waytogo:
  2. dyeager535
    26,980
    The problem you are no doubt finding, is that it seems that since every application is different, not everyone has the same problem. What could be proportioning in one application, might be master cylinder in another.
    Not much help I know, but checking out Lepers post, see how many ideas are thrown out there, all of which are plausible causes?
  3. NewMexK5
    Jul 25, 2002
    201
    Carlsbad, NM
    Thanks, just saw the Lepers post right above mine.
