Need help choosing an engine
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rowdysr, May 6, 2003.
  1. Rowdysr
    Rowdysr Registered Member
    Nov 18, 2000
    20
    Whidbey Island, WA.
    Currently I have a 305 in my 85 k5. I was going to change over to a 350, but I've just come across a deal on a 383 and I'm not sure if this is going to be the right engine for my needs. I want something that will be good for having fun off road, but also good for towing. The motor also comes with a turbo 350 tranny, but is not set up for the t-case yet. Any knoledge you could share or advice you could give would be greatly appreciated. /forums/images/graemlins/k5.gif
  2. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    not set up for the t case? are you sure its not a 2wdrive tranny? and yes a 383 is a great towing motor and it also has the punch and is snappy like a 350 sounds like a good deal. make sure its the right tranny though.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Take the 383. It has more torque than the 350 will put out at low RPM's. The TH350 should handle it, make sure it's a 4x4 tranny, if not, you'll have to switch it over.
  4. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    CoughDIESELcough
  5. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    That would be my choice! /forums/images/graemlins/thumb.gif 5.9 Cummins swap...
  6. Rowdysr
    Nov 18, 2000
    20
    Whidbey Island, WA.
    The guy that's selling it said that the tranny is not put together yet. How do you switch it over? Is it costly? and is it something that I could do myself? /forums/images/graemlins/k5.gif
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    ummmm the 383 should mate to your existing tranny..... a 305 block is the same as a 350 ( at least that is what i am told ).... and a 383 is a stroked 350... so just grab the motor and put it in.... and HELL YEAH TORQUI SHE BE!!!!!! /forums/images/graemlins/deal.gif
  8. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    383 is a killer setup! lots of torque
  9. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    1st choice: 383... good cause it'll bolt up to most of the stuff on a stock 305 or 350 so the swap is cheap. Good torque at low rpm.
    2nd: cummins 5.9L turbo diesel. $pendy conversion Im sure... but 555 ft/lbs at 1400 rpm + 350,000 mile service life + decent mileage = one of the most appropriate-to-be-installed-in-a 4x4 engines ever made.
    j
  10. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    It would just be in the re-assembly of the transmission. You need the output shaft from a 4x4 version. It will just go in place of the 2wd output shaft. I heard something about advanced adapters selling it, but I'm not sure.
