Need Help, Cooling System?, Engine?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by schlechto, Apr 11, 2002.
  1. schlechto
    schlechto Registered Member
    Aug 4, 2001
    56
    Carnation, WA
    I noticed that my radiator overflow bottle has, well, overflowed.
    It seems that for some reason too much fluid has been going into the overflow pipe instead of staying in the radiator. When I popped the hood to check the tranny fluid I freaked out because I saw fluid boiling up out of the resevoir.
    Your help will be greatly appreciated,
    Ben
    1987 GMC Jimmy 6.2L Diesel
  2. dyeager535
    26,980
    Re: Need Help, Cooling System
    Only two things I have to add:
    I've seen stop-leak do this. It gets into the overflow bottle, and every time water gets in there, it acts as a check valve. Eventually it overflows.
    If you've got air in the radiator when its running (bubbles) you could have a blown head gasket. Not sure that this would push fluid into the overflow bottle, but I guess it could if it increases the cooling system pressure enough.
  3. schlechto
    Aug 4, 2001
    56
    Carnation, WA
    Re: Need Help, Cooling System ?, Engine ?
    Anybody else ?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Your engine is over heating for some reason.
