Need Help: D60 spindle bearing installation.
Discussion in 'The Garage' started by MuddinManny, Jan 15, 2007.
  1. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Hi Guys,
    Need a little help. Search only brought up how to remove not install.
    I am ready to install my D60 needle bearings in the back of my spindles. I'm going to use the heat/freeze method...spindle at 400* in the oven, bearing in the freezer for 30 minutes or so.
    My question is this: all pics from instuction manuals I have are inconclusive. I didn't pull the bearings. There is a line inside the spindle cavity where the bearing goes. Do I press it to that line, or all the way in? Is there a seal that sits on top of the bearing on the inner side?
    The diagrams indicate that all the seals press against the oil sligner and that forms a seal with the back side of the bearing.
    I can't make heads or tails of the diagram pictures. Here are my pictures from the disassembly.
    Looks like there are seals in place????
    Definitely seals????
    A little help please. I have Dana Spicer B & S Kit 700014 from ORD.
    Thanks,
    Manny
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I usually use a bearing/race installer to get it most of the way in, then use the old bearing to set it a little deeper. If you look at teh spindle seals you can tell how deep it needs to be.
  3. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Thanks ReadyMix!
    I had to call ORD to order, and so I spoke with Stephen. He relayed the same information you did. I need to take these to a shop and get them pressed in. Thanks for answering!
    Manny
