NEED HELP FAST! Can i drive 30 minutes away with a busted heater core??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zakk, Nov 1, 2002.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I got water all over my pass. side, leaking like the Titanic. Can i make it 30 minutes w/o overheating or anything like that??? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    I doubt it. Try capping the line comingout of the radiater or atleast pinching it with vise grips...
  3. rogerwilco71
    Sep 22, 2002
    179
    Central-Cal
    well, reason a say doubt it, is because of one of my horrors of overheating...had and engine('77) over-heat in winter and ending up with a cracked cylinder. Maybe cause outside temp? IDONNO..
  4. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    agreed, you will need to pinch it off or bypass it. I'd take the 3/4" hose off the heater core, and move it to the intake port (where the 5/8" hose comes from for the heater core) so that it effectively bypasses the whole system. All you should need is one flat head screw driver, and a little elbow grease to make it work. Top off the coolant, and drive with confidence... just no heat! /forums/images/graemlins/wink.gif
    Good luck!
    -Dan
  5. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    do what krazie siad, just run one of the heater lines from the radiator to the intake manifold, it will just bypass the heater, it wont leak and will work just fine
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Another vote for Krazie87k5's idea. Been there, done that, and except for cold hands and feet, it worked fine (no harm to motor).
  7. Grim-Reaper
    7,385
    Atlanta
    Yeah like Krazie said. Just loop the intake to the radiator and bypass the heatercore. It will be fine that way till you can replace the heater core.
