Need Help fast canopy glass removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1bigk10, Jan 3, 2002.
  1. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    I need to know how to remove the glass from My solid window top. Need help A.S.A.P 1982 K10 Silverado. <img src=http://coloradok5.com/forums/images/icons/cool.gif> 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  2. dyeager535
    26,980
    Pull the trim strip out of the center of the seal, then slowly and carefully work the seal out from the canopy. Believe I did mine from the inside out. You can use a screwdriver, but if you hit the glass with it, you won't have to worry about the window anymore. A wooden implement would probably be best, but that said, I used a screwdriver to maneuver the gasket out.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
