Need Help Fast! Dana 60 Pinion/Carrier Bearing #s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kpanza, Mar 14, 2002.
  1. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Hi all,
    Was hoping that someone could help me out real quickly with these bearings for the front Dana 60. The axle is out of an 88 V30 Crewcab, so has the 35 spline axles. I need to get a set of carrier bearings and also the pinion bearings - does anyone know the part numbers I need off hand? Or perhaps a part # for the whole rebuild kit? The parts stores around me are worthless, they must not deal with the 60s that often.
    Thanks for any help, I figured with a part number I might be able to get them to find it!
  2. bklynlifted
    bklynlifted 1/2 ton status
    Feb 4, 2002
    261
    brooklyn ny home of the brave
    dana master install kit part #35-2034 from 4 wheel parts warehouse call their lynwood washington store ask 4 jon. just bouble ckeck the part # he can also check their california stores stock near your house .
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Parts List:
    Itema Item Part Description More Info
    001 Contact Vehicle Mfg. HOUSING - AXLE SERVICE More Info
    002 CHRY_60F(TAB) TAB BILLS More Info
    003 34643 SLINGER - PINION BEARING INNER More Info
    004 706046X INNER PINION BEARING KIT More Info
    006 706359X KIT - PINION BRG ADJ SHIM More Info
    006 708020 KIT - DIFF & PINION ADJ SHIM More Info
    007 706045X OUTER PINION BEARING KIT More Info
    008 42737 THRUSTWASHER - BEARING More Info
    009 42449 SEAL - PINION More Info
    010 34592 SLINGER - END YOKE More Info
    011 CHRY_60F(VAR) VARIABLE PARTS TABLE More Info
    012 30275 WASHER - PINION NUT More Info
    013 30271 NUT - PINION More Info
    014 CHRY_60F(VAR) VARIABLE PARTS TABLE More Info
    015 CHRY_60F(VAR) VARIABLE PARTS TABLE More Info
    016 43180 PLUG - CARRIER COVER More Info
    017 34822 BOLT - CARRIER COVER (QTY 10 More Info
    018 34687 GASKET - CARRIER COVER More Info
    019 Contact Vehicle Mfg. HOUSING - AXLE SERVICE More Info
    020 48632-1 BOLT - DIFFERENTIAL BEARING CA More Info
    021 706047X DIFFERENTIAL BEARING KIT More Info
    022 708012 KIT - DIFF BRG ADJ SHIM (INC 1 More Info
    023 CHRY_60F(TAB) TAB BILLS More Info
    024 30266 BOLT - DRIVE GEAR (QTY 12) More Info
    026 34367 PINION More Info
    027 34729 THRUST WASHER More Info
    028 34730 THRUST WASHER More Info
    029 44810 LOCK - DIFFERENTIAL SHAFT More Info
    030 30263 DIFF SHAFT More Info
    031 36487 SEAL & GUIDE TUBE More Info
    031 706395X KIT - KING PIN PARTS More Info
    032 620058 SEAL - KING PIN - UPPER More Info
    033 37305 RETAINER - GREASE More Info
    034 41777 SEAL - OIL More Info
    035 706150X KIT - BEARING - KING PIN - L More Info
    036 620143-3 SCREW - STOP More Info
    037 500381-5 NUT More Info
    039 Contact Vehicle Mfg. HOUSING - AXLE SERVICE More Info
    040 500175-4 ELBOW LUBE FITTING More Info
    041 30875 NUT - HEX TAPERED More Info
    043 38520 ARM - STEERING (LH ONLY) More Info
    044 37307 GASKET - KING PIN CAP More Info
    044 620132 CAP - KING PIN - UPPER (RH ONL More Info
    045 37300 SPRING - PRESSURE More Info
    046 620180 GEAR More Info
    047 41886 BUSHING - KING PIN More Info
    048 37302 PIN - KING More Info
    049 43648 RIGHT KNUCKLE More Info
    050 43650 LEFT KNUCKLE More Info
    051 37879 BOLT - HEX More Info
    051 74559X KIT - RIGHT KNUCKLE ASSY More Info
    051 74560X KIT - LEFT KNUCKLE ASSY More Info
    052 37299 CAP - KING PIN BEARING LOWER More Info
    053 500357-13 LOCKWASHER (KING PIN CAP - LOW More Info
    054 500412-13 BOLT - HEX (KING PIN CAP - LOW More Info
    055 CHRY_60F(TAB) TAB BILLS More Info
    056 37308 SLINGER More Info
    056 700013 KIT - SPINDLE More Info
    056 700014 KIT - SPINDLE SEAL & BEARING More Info
    057 620062 SEAL - NEEDLE BEARING More Info
    058 37312 SPACER - WHEEL BEARING SPINDLE More Info
    059 37311 SEAL - OIL More Info
    060 620063 NEEDLE BEARING - SPINDLE More Info
    061 620061 SPINDLE - WHEEL BEARING More Info
    062 36880 NUT - BRAKE MOUNTING More Info
    063 48816 SEAL - GREASE More Info
    064 706411X INNER WHEEL BEARING More Info
    065 706074X INNER WHEEL BEARING KIT More Info
    066 Contact Vehicle Mfg. HOUSING - AXLE SERVICE More Info
    067 CHRY_60F(VAR) VARIABLE PARTS TABLE More Info
    068 CHRY_60F(VAR) VARIABLE PARTS TABLE More Info
    069 CHRY_60F(VAR) VARIABLE PARTS TABLE More Info
    070 CHRY_60F(VAR) VARIABLE PARTS TABLE More Info
    071 CHRY_60F(VAR) VARIABLE PARTS TABLE More Info
    072 CHRY_60F(VAR) VARIABLE PARTS TABLE More Info
    073 37730 SNAP RING More Info
    074 CHRY_60F(VAR) VARIABLE PARTS TABLE More Info
    075 Contact Vehicle Mfg. HOUSING - AXLE SERVICE More Info
    900 CHRY_60F(TAB) TAB BILLS More Info
    901 CHRY_60F(TAB) TAB BILLS More Info
    902 CHRY_60F(TAB) TAB BILLS More Info
    903 CHRY_60F(TAB) TAB BILLS More Info
    904 CHRY_60F(TAB) TAB BILLS More Info
    905 CHRY_60F(TAB) TAB BILLS More Info
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    <a target="_blank" href=http://www2.dana.com/expert/expert.htm>http://www2.dana.com/expert/expert.htm</a>
    problem is I think these are all OEM numbers not common Timken
