Need Help FAST TBI--Carb
Discussion in 'The Garage' started by Ben B., Nov 9, 2005.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    Well guys I really need you here....i'm in the middle of swapping a TBI 305 to a carbureted 305, well the new motor runs great, and everything's bolted up....now my buddy and i are just troubleshooting.
    The current and probably last problem: Electrical Problem: When you fire the truck up and stop turning the key so it runs, it'll fire up for a second then die, now if i leave the key cranked all the way, the motor will run good...but we all know you can't do that....Any ideas? :doah:
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Did you put a manual fuel pump on it? If not the ecm is prob confused because its not getting info from the tb sensor anymore and is killing the fuel pump. :dunno:
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Have you hooked up ur HEI feed to a start hot only instaed of start and run hot feed by mistake?
  4. Ben B.
    Sep 1, 2005
    352
    Central PA
    I have disconnected the Electric fuel pump and the mechanical one is working fine and pumping gas.
