Need Help Fast!!
Discussion in 'The Garage' started by txfireman110, May 13, 2004.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    I'm swapping the 350 out of my K5 and putting it in the K30, and vice-versa with the 454 out of K30 into K5.
    What do I do about motor mounts????? I was told that 350 motor mounts would work in both trucks, but they don't match up to the holes where the 454 was??? Do I have to swap the hole support that the mount bolts to????
    Thanks /forums/images/graemlins/bow.gif
    ***also...., what about the tranny crossmembers???? I looked, and measured, and nothing is lining up /forums/images/graemlins/doah.gif Do I have to get new crossmembers all together????????
    Please Help before I shoot myself or my K5 /forums/images/graemlins/crazy.gif
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    TTT sorry i cant help /forums/images/graemlins/dunno.gif
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I think you should beable to use the same motor mounts, and I think you may have to get a new cross member /forums/images/graemlins/dunno.gif
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you need the correct motor mounts for what ever motor was original (bbc,sbc) they will work with any chevy motor.
  5. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I was under the impression that you could swap a bbc and a sbc freely and that all the chev motor mounts were the same...
  6. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    The steel brackets that bolt to the engine have the same bolt pattern ,but they are made in 2 different configurations--truck ones differ from passenger car ones,the bolt hole for the thru bolt are aproximately 1 inch farther away from the block on the truck ones.I have seen in repair manuals pictures of the pads that bolt to the crossmember (the motor mounts)being bolted into different holes for a big block vs.small block,but I've swapped in more than a few and never had to move them--cant explain why! /forums/images/graemlins/dunno.gif
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    My 6.2 diesel dropped right into the sbc motor mounts on the truck...I can't imagine a bbc being any different.
    Rene
  8. sr175
    sr175 Registered Member
    Mar 31, 2004
    76
    Tracy, CA
    I just pulled out a 454 out of my truck and put a 350 in using the same clam shell mounts except I replaced out the nasty rubber for poly. Works fine as far as mounts go...
