NEED HELP FAST....
Discussion in 'Tow & Trailer' started by BlazerWheels, Nov 26, 2003.
  1. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    On my trailer I have brake lights, running lights, left and right turn signals...when the running lights are on and the brake is pressed, the lights go off. Only to come back on when the brake is released. Is this a grounding issue? Crossed wire? Something else? /forums/images/graemlins/confused.gif Need help fast as We are leaving this afternoon....
    Thanks in advance. /forums/images/graemlins/thumb.gif
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Do the brake lights work fine when the running lights are off?
    Do all the running lights go off or just the tail lights when the brake pedal is pressed?
  3. BlazerWheels
    Feb 13, 2003
    587
    California
    Yes. Brakes work as normal when running lights are off.
    It is a small trailer, so the only light on it are the tail lights. But yes they go out completely.
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Sounds like a grounding problem to me. At least that is what I would start with.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Check the wiring to the lights. Sounds like you have a crossed wire. The bulbs have a common ground. If you wired one of the power leads to the ground, you could see behavior like this. That's my best guess...
  6. BlazerWheels
    Feb 13, 2003
    587
    California
    I will check this out. Thanks.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I just realized, I should have qualified that with "as long as you have it grounded". Sounds to me like your getting an intermittent ground through the switch in any case... The loop ground is not there when the switch is "on" so the lights go out when both are energized. Make sense?
  8. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    It is def. a ground related problem.. Check your ground to the tow rig.
    I have had this exact problem many times. It is the Ground. /forums/images/graemlins/thumb.gif
    John
  9. BlazerWheels
    Feb 13, 2003
    587
    California
    Just wanted to say thanks for all of the replys. I found the problem...the lights had lost a bulb /forums/images/graemlins/ignore.gif /forums/images/graemlins/blush.gif...I thought my dad checked that. OH WELL, just a reminder to check the obvious first.
