need help finding out gears.
Discussion in 'The Garage' started by Chrisblazzer89, Feb 12, 2007.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Ok i just pulld off the covers off my old 10bs and i wanna know wat gears i had here is wat i got out of them GM 1235 15 41 1287
    OR GM 235 5 41 287
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    divide 41/15
    wow....... that doesn't seem right, that would put you at a 2.8xxx ratio ???
  3. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    that would mean 2.73333333
  4. resurrected_jimmy
    May 23, 2005
    2,241
    any chance that "15" was an 11
  5. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Let me go check
  6. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    ok i missed some #s hre are exacltly wat i got off of the ring 1 GM 1235124 15 41 1287
  7. resurrected_jimmy
    May 23, 2005
    2,241
    41 should be the number of teeth on the ring gear and 15 should be the number of teeth on the pinion..... I'm not believing it somehow. If you really want to know,mark your start point and count ring gear teeth and pinion teeth and divide
  8. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    quite possible!..
    Many 80's 10 bolts had 2.73 gears...3.08's were the most common,I've also seen 2.56 and 2.29 ratio 10 bolts!...all in the name of lower emissions and more mpgs..
    I think you could also get 3.42's,3.73's,4.11's,and 4.56's factory option,in 10 bolts..:crazy:
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yep ive heard of 2.73's before
  10. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    That's right.
    I have an 88 with 2.73's and another set of 10 bolts with 2.73.
    Not terribly uncommon....
    John
  11. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Yep I have seen 2.73s in blazer 10bs. Holy crap that sucks. Nice thing is 3.73s should cost you about 20 bucks on ebay :D Hell if you want em give me till this summer and I will give you some 3.73s
  12. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    No i was just wondering wat i had I know have 3/4 ton gear with 4.10s 14Bff rear and 10b 8 lug
  13. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Good. It would definitely be a bad idea to run 2.73's with 38's.
    -Harrison
  14. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    :haha: lol yeah seriously!!!:haha:
  15. resurrected_jimmy
    May 23, 2005
    2,241
    I never knew they used that high of a ratio with a 700R4, no wonder the trans burns up as soon as you add slightly bigger tires
  16. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Yep guess so happy i now have 4.10s and will soon have 38s.
  17. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    my 83 had 2.73 and a 700r4. it was great when I put 35's on it.
