Need Help finding the right differntial covers!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tuskadero, May 23, 2001.
  1. Tuskadero
    Tuskadero Registered Member
    Jul 14, 2000
    91
    Southern California
    Hi everyone,
    I need new diffrential covers, the ones I have on now are crome. The front one is rusted but doesnt leak, I want to change it though. The back one leaks, I put a new gasket and sealer on it and it still leaks. I'm thinking about ordering the rear one from that Mag- Hytec company but there so expensive does anyone have any suggestions thanks,
    Heather
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    For your leak in the rear you could try using RTV sealer only and no gasket.I do this front and rear and never have leaks.Just make sure the mounting surface on the cover is flat before you put it back on. For the rust on the front cover, try scrubbing the rust with some steel wool. Soak the wool with some car wax and scrub away.If its not too bad the rust should come off .Good luck.
    All work and no beer makes Frizz a dull boy<P ID="edit"><FONT SIZE=-1>Edited by FRIZZLEFRY on 05/23/01 11:33 AM (server time).</FONT></P>
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    You could use mothers. A lot of times that takes rust off. i don't use gaskets on my diff covers....just the silicone gasket maker stuff.
    Imagine a cowgirl twirling a rope.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    yeah gaskets don't work real great on diffs IMO. Just put a nice bead of rtv on the cover after you pull and clean it. Circle around the bolt holes and I usually let it sit a couple of minutes and kinda set up or get stiff, but not too stiff... that way it all doesn't ooze out.
    Some people frown on the chrome diff covers cause they hold in heat. I'm gonna run them on mine... figure I won't worry too much about it cause I use sythetic 80W90 Valvoline in the rear anyways... plus I change it quite often. Alum covers will yield heat better... you can also look into the re-inforcing covers that screw in to the main caps to prevent flex. LPW and Summit sell these for about $130 or so.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
  5. 77GMC15
    77GMC15 1/2 ton status
    Mar 14, 2001
    110
    Vacaville, CA
    Put the steel wool in some Coca-Cola that will get it right off. Try just a sponge if there is any on the outside of it.
  6. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    the problem is most of the chrome ones are paper thin off shore stuff. i run danas with the thick covers and never have a problem with the gaskets except finding them.
