Need help? F'n Truck won't start!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rocky91, Mar 22, 2002.
  1. Rocky91
    Rocky91 Registered Member
    Feb 14, 2001
    44
    Rochester, NY
    Need help? F\'n Truck won\'t start!
    Went to start my truck this morning and it wouldn't start. I put the key in the ignition and the warning buzzer went off cause the door was open but once I moved the key to the start position it stopped and there wasn't anything. Nothing clicked or attempted to start. After that the warning buzzer wasn't even working anymore. I opened the hood and checked the battery, but it had a full charge, wouldn't even draw a charge when I put it on the charger. Is it possible that my ignition switch went bad?
    For a little background, we have had an unusually mild winter and last night was the coldest night so far this winter. The only night the temperature dropped even close to 0*. I don't know if possibly something is just frozen or to cold to want to work. Too cold to even work on the truck for very long. Thanks for the input.
  2. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Re: Need help? F\'n Truck won\'t start!
    The first thing I would check is the fuse. If it is bad the truck will not do a thing.
  3. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Check the wires going to the back of your Alt. This is where the power for the truck runs from in many situations.
    good luck,
    Mike
  4. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I think this happend to mine the first winter I got it. I think there was water frozen in the starter soleniod. I would look for problems around the starter/ solenoid.
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Two causes.... The afore mentioned starter problems, or the neutral/park start safety doohicky. Sorry for being technical with the name here. The unit sits on top of your steering column before it enter the firewall. What it does prevent the truck from starting when it is in anything but park or neutral. I belive it controls the back up lights too. The on my '81 is screwy and I have to jiggle it a bit and move the shifter up and down before it cooperates and takes off.
  6. Rocky91
    Feb 14, 2001
    44
    Rochester, NY
    Got the truck started, thanks for the help guys. Your comments got me thinking so I went out a played around some more. Turns out the negative battery terminal is slightly stripped and came loose enough to cut power, guess I have to keep an eye on it and start thinking about replacing it. Thanks again.
  7. ChevBlazin
    Feb 4, 2002
    332
    Don't you love easy fixes!
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I had a problem similar to this awhile back. One night after work, I was under the dash installing a new CD player. Got up to go to work the next morning, went out to start the truck, and nothing happened. No click, no grind, no nothin. Checked the battery, connections were all good. I checked everything I coould think of. I had to pull out my Haynes manual with an electrical diagram and start tracing down anything that said ignition. Was already an hour late for work. Started tracing wires, and it turns out that while I was under tha the dash the night before, I had accident pulled the connector off the neutral saftey switch. Hooked it back up and it started right up. lol.....Lesson learned there. /forums/images/icons/smile.gif
  9. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Exact problem like mine, was corrosiion on the battery cable connection. When it happened though I was like WTF now?
