Need help from the 14bff gods!?!?
Discussion in 'The Garage' started by Beast388, Jan 22, 2003.
  1. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I have been helping my friend fix the 14BFF under his 96 Suburban. The pilot bearing at the nose of the pinion has disintegrated. We have removed the 5 bolts that hold the pinion assembly to the case, but we cannot pull it out. So...what is the trick? Is it just bolted on?.....or pressed on or ??????? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    Any help is appreciated!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  2. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I believe you should be able to pull it out.I would pull the diff covr and make sure there isn't any pieces of the bearing jamming in there.If the pinion bearings are that bad I would check the carrier bearings also.And clean the inside to make sure there is no metal pieces floating around.Hate to get it back together than have it really tear something up!Brady
  3. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Take out the 6th bolt. /forums/images/graemlins/wink.gif
  4. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Hehehe....so I lost count. /forums/images/graemlins/thumb.gif
    All the bolts are out. Any ideas? /forums/images/graemlins/confused.gif
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Beat it out. Sounds like it fubared on the inside anyway, so who cares.
    You can remove the carrier and see exactly what the holdup is.
    -- Mike
