Need help from you body work gurus please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ramjet gmc, May 12, 2002.
  1. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    I am trying to repair my blazers floor I am having trouble finding the cross brace where the rear floor meets the front floor at the bolts a cross with of the truck. (The part with the welded nuts on it in the middle of the truck)
    If some one has the name or some pic on the repair of this on their truck I also need to find this part the LCM book is not listing it
    Thanks for your help /forums/images/icons/wink.gif
  2. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    that part is not made to my knowledge. I hade to fabricate mine out of 1/4" plate that a guy put in his press and bent it for me. You can see pics of my whole rear floor swap at ... <a target="_blank" href=http://community.webshots.com/album/22742026nbhEtBOZnc>http://community.webshots.com/album/22742026nbhEtBOZnc</a> If you have any questions or anything give me a shout.
    Ben 87 Jimmy
  3. bking
    bking 1/2 ton status
    Jan 4, 2001
    176
    Alaska /Here from Ireland in Dec 2000
    That was a most excellent link.................
  4. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Are you talking about just the outer edges with the nuts? Any two bit body supply shop should have them. Look on the bottom of <a target="_blank" href=http://www.73-87chevytrucks.com/blazers.htm>here</a>. They're cab mount patches/replacements. Personally, I don't see replacing a faulty system with the same. I used 1/8" box tubing for my toasted subframe. I had to cut some inspection panels in my floor to get at the new nuts, but if you've ever had a caged nut assembly jump the cage, you'd switch too. Itali83's looks really professional, mind looks kind home brew if you look close, but only the trained eye would pick up on it being different. I just welded the edge of box tubing to my rocker because it was the most stable thing there. I thought I'd test my idea one day and stood right one the tube (floor wasn't in yet) to try it out. I weight about 210 and had all my wieght on one foot, and it held!
  5. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Year one and Cheyenne truck parts also sells the front and rear cab supports. Raybuck autobody parts sells channel type crossmembers as well as cab mounts. I like the idea of the box tubing if mine rotted out I might go that way.
  6. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    Thanks for positive replies guys.
    Ben 87 Jimmy
  7. ramjet gmc
    Dec 19, 2001
    3,370
    Itali83 that’s what I need thank you
    looks like I need to buy a welder
  8. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    No problem, let me know what you do and I'll gladly help you out with tips and more pictures if you need them. Keep in touch and best of luck to you!
    Ben 87 Jimmy
