Need help Getrag NV3500 or NV4500?
Discussion in 'The Garage' started by 64suburban, Sep 28, 2006.
  1. 64suburban
    64suburban Registered Member
    Feb 9, 2006
    57
    tn
    Help! I have a 64 suburban, i'm converting it to 4 wheel drive, I want a 5 speed manual transmition. I know little about the NV3500 or the NV4500 except that the housings are differrent. One is aluminum and one is cast iron. I want to use it with a np205. However I wonder if it will work with a 203, because I currently have one of thoughs. I just really want to know which one is better? Thanks alot!
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Not getrag and not 3500
    That narrow it down for you?
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    NV4500 hands down. A 203 can have the face redrilled so it'll bolt up behind the NV4500. You will need a short 32 spline input for the 203 though.
    Rene
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    The NV3500 is on the lighter side of truck transmissions. The NV4500 is way stronger and has a lower first gear (there are two different versions and both have a lower first gear). I have no idea which Getrag transmission you are considering. Some of them are very stout but are probably difficult to adapt to any engine/trans you are looking at.
  5. 64suburban
    Feb 9, 2006
    57
    tn
    Thanks for the information!
    Thanks for the information, that helps out alot guys. I might use the 203 if I run out of $$$$!
    Thanks,
