NEED HELP GUYS>>>
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tonyb5150, Mar 28, 2003.
  1. tonyb5150
    tonyb5150 Newbie
    Mar 26, 2003
    Hey guys great site! I am about to lose it after working on my K5 for two weeks.
    1989 K5 350 TBI
    Starts and Idles but bogs on acceleration and is undrivable due to the stalling. It always starts right up and idles smooth..the thing bogs bad when give gas!
    Thinks I have done
    TBI GASKET
    Fuel Pressure Regulator
    PLUGS
    Wires
    Cap and Rotor
    Coolant Temp Sensor
    Checked Cat
    NEW Distributor, IGN Pick Up coil, IGN module
    Fuel Filter
    EGR seems to move
    Replaced Computer and had no change so took it back
    Am I forgetting or missing anything?
    Orginally I have had no codes..but now I have a code 22..but I think it is because I unplugged it last night. Any tips? Thanks and rock on!
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Sounds like the dist is off 180 degrees? Don't know much about TBI. But I messed up a distributor install once and it idled fine but with any load it'd stumble. Good Luck. Keep us informed
  3. ds350
    ds350 1/2 ton status
    Jan 26, 2001
    190
    Bay Area
    I 2nd with Jimmyjack on the distributor.
    Are you sure that you are not having transmission problems?
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The TPS (throttle position sensor) may be bad. Located on passenger side of the throttle body.
    If the computer does not see the throttle opening it wont give any gas = dies when opening throttle.
    Code 22 shows a problem TPS circut.
    It really helps to have a scanner when looking for these problems. it will save you a lot of money in the long run.
    Auto X Ray scanners are only 140 bucks its a lot cheaper than replacing parts till its fixed.
