Need help - How to adjust the TPS on a Holley TBI for SBC
Discussion in 'The Garage' started by Emmettology 101, Jul 1, 2003.
  1. Emmettology 101
    May 9, 2000
    8,126
    FL
    Anyone know how? I haven't had much time to surf Holley's site today so I thought I would post this up here just in case I come up empty handed.
    Right now I have it set in the middle, but would liek to see if it is out of adjustment.
    Thanks!!!!!
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If it's hooked up to the stock GM ECM, then you need to adjust it to factory specs for the truck. The ECM doesn't know that you have a different TBI on there, so it's expecting the stock parameters. /forums/images/graemlins/cool.gif
  3. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    how much did you pay for that cuz im lookin at getting one of those or just going over to a 4bb. Id kinda like to keep the FI but this damn TBI has been one thing after another... Is it the 670 TBI om replacement one?
  4. dyeager535
    26,982
    191
    Some of the replacement Delco TPS' (and perhaps some stock ones) are adjustable by loosening the two screws that retain it, and just turning it. The stock ones I've seen do not have this feature.
    The non-adjustable ones, from what I can tell, are not adjustable. Perhaps you can get some adjustment through loosening the screws if there is a little play.
    '88 Camaro manual says hook up a scanner, check for idle TPS voltage over 2.5 volts at idle, plus or minus .08 volts. Voltage should increase at a steady rate when the throttle is increased. Should reach 5 volts at WOT. Voltage should go below .2 volts if it is disconnected.
    Says any voltage under .7 volts the ECM will auto-zero to 0% throttle.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    My buddy bought it a while back and we just stuck it on there. Not sure what they run. And yes, I believe it is the 670cfm with 2" bores...
  6. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    Hook 2 wires to the Blue and black wires on the tps,
    (+) for blue
    (-) for black
    Hook a voltmeter to them
    plug in the TPS
    turn on the ingition key to on
    adjust TPS to 0.63-0.65 volts
    Atleast thats what the book sais..
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    thanks!!!!
    So do you ground out the pins on the top right hand side of the diag plug to get codes?
  8. denver75k5
    May 15, 2001
    1,017
    Im not sure , you kinda lost me on that one /forums/images/graemlins/thinking.gif
  9. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    how do you adjust? I need to right now but I have no clue how you do it.
  10. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    To actually do the adjustment you loosen the two screws holding the TPS in place and rotate it either way until you get the proper voltage reading from it.
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    they claim the TBI one is not adjustable. How do I clear my codes? I can't find it in the service book. It says see "section 2" when everything goes by chapters! I think I want my carburation back. I'm just gonna take it to my mechanic. I hate computer controlled vehicles I really do, I remember why now.
  12. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    If it's the stock GM TBI you can't adjust the TPS, but on the Holley TBI you can. I know what you mean about computer controlled crap. I love mine when it works but tracking down problems and bad sensors is a pain. /forums/images/graemlins/frown.gif
