need help, I got a lift question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rebel222, Nov 8, 2000.
  1. rebel222
    rebel222 Registered Member
    Aug 21, 2000
    58
    Louisiana
    I FINALLY GOT MY BLAZER MOVING!!!!!!!!! Now that it moves I had to test the 4wd. Shouldn't have done that yet. It vibrates a lot when in 4wd. I have heard of vibrations with the driveshaft angles, but this only has 2 1/2" of lift. Is that enough to make it vibrate that bad? Could it be a bent driveshaft or a bad u joint? Any help would be appreciated. Thanks
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Its probably a bad u-joint
    90K5
  3. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    This may sound stupid...but make sure that the transfer case is locked into gear all the way. When i had my exhaust done, they thought the tranfer case shifter was the tranny. As a result, when I got the truck back, It had a hidious vib'. When I checked the transfer case, it wasn't in gear all the way. Just a possibility. Good luck!
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I don't know if this would matter, but it would be a good idea to check anyway. Make sure the transfer case has enough fluid in it.
    90K5
