Need Help. I got my M/T MTZ's 36x15.50 now.....
Discussion in 'The Garage' started by victory65, May 11, 2005.
  1. victory65
    victory65 Registered Member
    Feb 1, 2003
    Newberry, Mi.
    I need help. I got my 36x15.50 tires today and I'm not sure if a 6" lift will be enough. I don't want to trim the fenders or use blocks. Here is my thinking. I could use a set of zero rates front and rear and if I have to, I could do the shorter of the two shackle flip kits for the rear, but what about the front?
    I forgot to mention that the truck is a "72" K-5 Blazer. Right now the truck sits level, but I've read that getting the lift kit it will sit lower in the back cause the lifts are actually designed for the pick-ups.
    I was also wondering about the rear driveshaft. If I correct the angle to withen 3 degrees of eachother and get it lengthened appropriatley will it be good enough?
    Any help is greatly appreciated.
    Rob (victory65)
