Need Help Identifying 14 Bolt have #'s
Discussion in 'The Garage' started by az88k5, Apr 26, 2006.
  1. az88k5
    az88k5 1/2 ton status
    Oct 14, 2004
    258
    Prescott Valley, AZ
    Need Help Identifying 14 Bolt Gears! Have some numbers for you guys. Help me out. 4.10 or 4.56?
    -6 3977334 10 41 2 74 GM2
    AZ88K5
  2. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    4.10. the "10 41" gives it away. 10 teeth on the pinion, and 41 on the ring gear.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    4.10
    The 10 is the pinion gear teeth, the 41 is the ring gear teeth. Divide 41 by 10. I *think* the 2 and 74 are the date code, and 3977334 is the part number.
    If I remember right, the 3.73 gears are 11 and 41, and the 4.56 are 9 and 41.
  4. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    Thanks ya'll, that helps me out a lot, and I need all the help I can get
  5. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    4.10 in 1974 definitely
