Need help identifying leak from pic
Discussion in 'The Garage' started by laketex, May 26, 2004.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    ....And what I need to do to solve it. The excretement is a milky oil, like gear lube with water in it. Leak started after Badlands trip this weekend and is leaking out of both ends of axle in this same spot. Thanks in advance!
    Bryan
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Pass. side inner axle seal leaking most likely, pull the carrier and pop the old ones out and pound the new ones in and put the carrier back in, poof, no more leak. To verify jack up the drivers side a couple feet in the air or flex out on something and you should get some fluid running out of there.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    inner axle seals NOT fun /forums/images/graemlins/dunno.gif
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    "Milky oil" isn't that a sign of water mixed in the oil/gear lube?
    You go through any water on your Badlands trip?
    Possible seal failure.
    That a D60 right?
  5. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yeah thats a 60 and the dirt/water that he got in his diff is most likely what killed the seal.
  6. laketex
    6,220
    North Texas
    Gotcha...and thanks. I dont really have time to pull anything before I move. My hubs are unlocked and Tcase is in 2hi. If I just fill the diff as needed, can I daily drive it for a month or so until I can get into it and change those seals? /forums/images/graemlins/dunno.gif
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I wouldn't leave that contaminated fluid in it.
    I would at least pop the cover and hose out the the insides with a few cans of brake clean.
    Then top off the diff and try to keep it out of the puddles untill you can get it fixed.
