need help identifying tranny and t-case!!!
Discussion in '1992-Present Chevy & GMC models' started by chevy wrangler, Sep 27, 2006.
  1. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    well i need help identifying what kind of transmission and t-case is in my dads truck, here are the specs:
    1999 new body chevy
    z71 package
    5.3 lt
    and automatic
    any info would be greatly appretiated:D
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    4l60 or the newer 4l65. easy to spot. 4l65 has removable bell housing like a ford tranny or any stick tranny.
    tcase should have a tag on it. or cast in the case borgworner. chevy has started to switch over to them. if older new prosses. it will have a red round tag on the back in the middle area.
  3. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    i think the tag is blue i'll check it tomarrow, oh and thanks
  4. bggrnchvy
    bggrnchvy Registered Member
    Jan 21, 2005
    48
    Cupertino, CA
    4L60e and either an NP246 if its pushbutton or the NP263 IIRC if its floorshift.
  5. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    push button with
    4lo
    2hi
    4hi
    they should have a neutral button but its a light
  6. bggrnchvy
    Jan 21, 2005
    48
    Cupertino, CA
    I messed up, the NP263 should be whats under your truck, the floor shifts should be the 261.
  7. extremetahoe
    extremetahoe 1/2 ton status GMOTM Winner
    Jul 19, 2006
    214
    Lincoln Alabama
    If I'm not mistaken it could be the np241.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    being a Z71, it could have a 4L80E in it. i've looked at a couple recently that had a 4L80E and a 10 bolt out back. 16 bolts = 60E, 17 bolts = 80E
  9. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    umm so a 10 bolt is a 4L80E?? it has 10 bolts
  10. bggrnchvy
    Jan 21, 2005
    48
    Cupertino, CA
    They stopped using the NP241 on the NBS trucks.
    No half ton, being the only GM truck factory with the 10 bolt rear, comes factory with an 80e.
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i've seen at least 10 trucks like this, one of them being my buddy's 94. ironically, ALL of them that i have seen were extended cab shortbed Z71s.
  12. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,853
    280
    Truckee, CA
    No, he is saying 16 or 17 bolts in teh tranny, not 10 on the rear end.
    Its probably not a 4l80E, but theres a chance...
