Need help...Ignition problem in 80 K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Muddytazz, Oct 20, 2002.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Sometimes you turn the key and it will start, other times you turn the key and absolutely nothing(completely dead system). Battery is 2 months old, took starter in and it tested just fine, replaced ignition switch (not key switch). Is there anyway to narrow down which part of the ignition circuit the problem could be?
  2. Grim-Reaper
    7,385
    Atlanta
    Re: Ignition problem in 80 K5
    Cables. Sometimes battery acid gets inside the jacket and rots them out and it's not visiable.
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    oh, forgot to mention that I took the cable off and cleaned them and checked for continuity with my tester and they are good, I can even cross arc the starter and get it to spin with the cables hooked up.
  4. Grim-Reaper
    7,385
    Atlanta
    Hmmm Then I would start tracing back the trigger wire from the starter and check for problems. They some times get the insulating burned off on the exhaust and leaves a spot for corrosion to form.
    Might also be a bad switch or a bad starter interupt switch (that only lets it start in Neutral or park). Have you tried running it through the gears then back into park to see if that will let it start? I had some adjustment problems on my shifter and had to hold the shifter up to get mine to start.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I tried running the shifter through all the gears and still nothing. Damn, guess its time to just start tracing wires.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    One more try.
    When you have that problem again, don't go to another gear but try to wiggle it, sometimes it's fine adjusting that you need.
    The second thing you want to try is, when it doesn't start, try starting it by shorting the thick cable feed to the starter solenoid avoiding all the cabling to the ignition.
    If that works, then make a setup with relay or buy it from painless. I made mine and I never had a problem again.
