NEED HELP! K5 won't start
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kihlj, Jan 5, 2002.
  1. kihlj
    kihlj Registered Member
    Oct 16, 2001
    38
    Dallas, TX
    NEED HELP! K5 won\'t start
    I have an '89 K5 that I just lifted (4" w/ 35 X-Terrains) that won't start now. I have been able to drive a little since I put the lift on. I came home the other day from work and parked the truck in the driveway and there it has sat ever since. The symptoms are as follows:
    It does try to fire and certain things work like headlights, power doorlocks and windows. However, other things do not work like the horn, dome light, radio
    Any suggestions would be very appreciated!!!
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    Re: NEED HELP! K5 won\'t start
    a start would be to check fuses also check your fuel pump fuses and relays to see if it is working
    4x4k20
  3. kihlj
    Oct 16, 2001
    38
    Dallas, TX
    I'm sorry I forgot to list some things that I have tried. I have checked all the fuses in the fuse box under the dash. Also, I have had the battery checked it tested out fine. A friend of mine told me to check the fusible link that comes off the starter. I went to the dealership and the "starter/alternator guy" told me there was not a fusible link coming off the starter but said that there is one coming off the battery. He gave me some fusible link wire but I have not replaced the fusible link coming off the battery because it does not look bad.
  4. kihlj
    Oct 16, 2001
    38
    Dallas, TX
    Anyone????
  5. kihlj
    Oct 16, 2001
    38
    Dallas, TX
    Anyone????
  6. kihlj
    Oct 16, 2001
    38
    Dallas, TX
    Anyone????
  7. 4x4k20
    Mar 17, 2001
    1,699
    williamson ga.30292
    the fuel pump fuse and relay is located under the hood on the right side passnger firewall there is a plactic sheild that will pop off it has a fuse and some relays there check them
    4x4k20
  8. istallion88k5
    istallion88k5 1/2 ton status
    Jun 20, 2000
    139
    Cincinnati, Oh
    I have an 88 that this exact same thing happened to, went to replace the starter solenoid and found a fusable link off it and it was bad exact same problems fyi.
    If it aint a Chevy don't raise it up!
