Need help, K5'er stranded in Victorville with a EFI problem
Discussion in 'The Garage' started by Stephen, Nov 24, 2004.
  1. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Need help, K5\'er stranded in Victorville with a EFI problem
    Chris Raffo (retroblazer) is stuck in Victorville CA right now trying to find out why his '94-ish sub (TBI 383) won't run. He's supposed to be in chicago for turkey tomorrow, so this is obviously pretty bad.
    Anyone know how to find Jason "zcarczar"? He's in Apple Valley near there and might be of some help in some way.
    Otherwise, the problem is the timing keeps advancing and retarding by itself, surging.
    They replaced the map sensor, O2 sensor, verified correct operation of the fuel pressure regulator and pressure level and checked the ECM by replacing it with a new one. There may be more that they've tried but that's what I know. Also, it's not throwing any codes.
    Any ideas?
    Anyone in the area have a TBI chip that would run it without the distributor or know if he could delete the dist. and run a manual version without wigging out the ecm?
    Thanks for any help. This situation sucks.
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Re: Need help, K5\'er stranded in Victorville with a EFI problem
    Can he not unplug the EST (i think thats the name for it) the plug on the drivers side of firewall, manually set timing and keep it going? I think est is also affected by the knock sensor, maybe its screwin up?
  3. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I GOT A CHIP FROM MINE IF IT WILL WORK. NO DIST CONTROL. COULD FEDEX IT... GOT A ECM TOO FROM A 91.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We'll look into unplugging and see if it will work, thanks.
  5. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Mike (blazen91) is right up there too.
  6. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Stephen,
    How about the knock sensor? If that was sending erratic signal to ECM, that would advance and retard the timing unnecessarily. Do they have any kind of scanner with them?
  7. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Stephen, I posted on the so cal board, Mike (blazen91) should see it shortly and Jason (zcarczar) will hopefully see it as well. Jason works (dad owns) at a chevy dealership in apple valley so they could probably help him out, don't have there phone #'s though.
  8. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i have both their phone #'s but my cell phones dead and house line doesnt have long distance, anyone want to call them? PM me /forums/images/graemlins/waytogo.gif
  9. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    PM sent Brandon. Just send me the number and I'll call.
  10. lziffle73
    lziffle73 Registered Member
    Jul 25, 2004
    6
    Richmond, VA
    throttle position sensor can cause the surging if it isn't set properly.
  11. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Did you guys get it figured out yet? I could possibly run over there and help them. Do you know where they are at? My cell phone number is (760)963-0936.
  12. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I'll be around all day too. 760-963-9933
  13. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Is there an update on this? Just wondering what's going on.
