need help mounting my ORD engine mounts...lost instructions
Discussion in 'The Garage' started by juanblzer, Nov 24, 2005.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I have my offroad design motormounts but I can't figure out which end goes where on my frame? ANy tips? I removed them when I sold my motor and now I have a motor and want to reinstall them. Is there a top and bottom to these? Help!
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  3. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    dug up some olds pics of my engine swap, hopefully you can see something usefull
    [​IMG][​IMG]
  4. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I'm trying to figure out which side is up and which side is down on my ORD mounts (the part that mounts on the frame side). Anyone?
  5. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    ttt
    ttt
    someone help me please. :(
  6. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    The bushing part should mount to the frame.
  7. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I know that... silly
    but is there a top and a bottom to the bushing part? It looks like there are two different sides to each bushing portion. Which side is which?
  8. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
  9. gman454
    gman454 Registered Member
    Sep 23, 2005
    45
    East Hartford, Connecticut
    if I remember right there should be 4 holes drilled in the mount the two clossest together should mount on the top side of the frame. set it on the frame and you will see how it lines up. hope this helps :truck:
