Need Help, No Brake Lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by schlechto, Apr 3, 2002.
  1. schlechto
    schlechto Registered Member
    Aug 4, 2001
    56
    Carnation, WA
    It is like the post says I have all the lights, including turn signal but the brake lights do not work. What should I check?
    Ben
    1987 GMC Jimmy 6.2L Diesel
  2. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    Start with the fuses, if all good check the taillight bulbs. Do your rear running lights work? If the bulbs check out good, check the pedal switch. It is mounted under you dash just above the brake pedal. You should be able to push the pedal with your hand and see where it releases the switch, which makes your brake lights come on. It is adjustable. Good luck.
  3. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    To add to the above info Take a test light and make sure that you have power going to the brake wires when the pedal is applied,
    If not then I would bet that there is a short above the gas tank and you need to test the wires before the tank (inside the the frame rails)...mike
  4. lsak5
    lsak5 Registered Member
    Mar 19, 2002
    26
    Marietta, GA
    Hmmm, I dodn't have any reverse lights, any thoughts?
  5. lsak5
    Mar 19, 2002
    26
    Marietta, GA
    Hmmm, I don't have any reverse lights, any thoughts?
  6. dyeager535
    26,975
    Hijacking the thread, but check to see if they come on at any time as you go through the gear selector. If they do, it's the park/neutral switch thats out of adjustment I believe. If not, you've got two bad bulbs, or wiring problems somewhere.
