Need help??? No output from the coil
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by raptorGTA, Aug 25, 2003.
  1. raptorGTA
    raptorGTA Registered Member
    Aug 21, 2001
    16
    Maybe someone can help me that has done a TPI swap with a painless wiring harness. I do have power at the coil and the computer when in the start and run position. The tested distribiter and everything checked out O.K. Enyone have any ideas on what else it could be. Thanks
  2. raptorGTA
    Aug 21, 2001
    16
    Someone has to have some ideas.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    see if there is a burnt spot in the top center on the rotor. it might be shootin down the distibutor shaft to the oil pan. happened on mine before, but it was just hei. but thats just a blind shot in the dark.
    nathan
  4. tlbob
    tlbob Registered Member
    Aug 22, 2003
    29
    littleton,colorado
    i know that you have to run a lot larger wire to the power in put on the coil like 10ga. do you have an msd box? is it the stock coil? after market? normal hei? sorry i could not help more /forums/images/graemlins/frown.gif
  5. raptorGTA
    Aug 21, 2001
    16
    It is the stock external coil for TPI system. I also had the cap off the distributer and didn't see anything out of place. But my problem is that I'm not getting any spark out of the coil so the distributer would not have spark anyway. Thanks for the ideas, anyone have more.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Have you checked the resistance of the coil? That is how you test them.
  7. raptorGTA
    Aug 21, 2001
    16
    This is the second new coil. I thought the first one might have been bad so i took it back and got another new one. So I don't think its the coil but I'll test it to make sure.
