NEED HELP NOW!!!!!!!!!!!! F**KING FLEXPLATE IS GONNA KILL ME! (update)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Jan 3, 2003.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    OK i just fought with the tranny and t-case all f**king day and when i got the old plate off i noticed it has a balance weight on it and my new one doesn't!!! /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif this would mean that my engine is externally balanced (right???) and that this new flex plate is for an internally balanced engine. (right?) i need help NOW! i need the suburban running tomorrow or sunday at the latest! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif will this new flexplate work with my engine or do i need a different one???!!!! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    update: my engine is externally balanced, i went to national performance center and got the right one so i'm set. /forums/images/graemlins/smile.gif but now it's too phuqing dark to do anything. /forums/images/graemlins/frown.gif
  2. unsane
    unsane Guest
    Re: NEED HELP NOW!!!!!!!!!!!! F**KING FLEXPLATE IS GONNA KILL ME!
    is it a 350? if so they are internally balanced. only 383 and 400 are external i think.
  3. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    If this is for your 89 and its a stock 350 it has a external balanced plate. The newer ones have this, I ran in to the same problem when I had a 88 burb. All the old 350's where internal balanced. Not sure of the cut off year
  4. muddysub
    Jun 23, 2001
    10,452
    489
    yes sorry tbi 350 completely stock
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You need the one with the weight. /forums/images/graemlins/frown.gif
  6. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    OK i have an 86 blazer and the 305 was externally balanced. When i built my new 383 i had it internally balanced at the machine shop but i had it done with a counter weighted flexplate therefore i still had to have a counterweighted plate. Moral is get one with a counterweight or it will rattle your engine apart. /forums/images/graemlins/deal.gif
  7. BCB2
    BCB2 Registered Member
    Jan 1, 2003
    11
    Wisconsin
    blaznreb, is the flex plate attached when the motor is balanced? I guess I don't understand why you would still need a flex with the weight if the motor is balanced internally. I have never had a motor balanced (or built for that matter,yet) so I am just trying to learn the ins and outs of this. I know the 400 in my bogger needed the weight, but since the truck is a four speed the balance weight was a seperate part bolted on with the flywheel.
  8. JAXSTER
    JAXSTER 1/2 ton status
    Mar 15, 2000
    181
    DFW, TEXAS
    On 86+ One peice rear seal the flex plate has a recall The weighted flexplate is the Latest due to a Vibration even if the crank is Balanced.
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Your bottom end was balanced at the machine shop, but it's externally balanced. That's what is meant by having a balance weight on either the flexplate or the harmonic balancer. An internally balanced engine has all of its balancing weights inside the oil pan (i.e., the crankshaft counterweights). /forums/images/graemlins/cool.gif
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    When a shop balances the rotating assembly, it first weighs the pistons, to find the lightest one. Then they remove weight from the others to match the lightest one. Next they do the same thing with the connecting rods, weighing both the small ends and the big ends and matching them up. Now they know the weight of each piston, wrist pin and rod assembly.
    Next they attach bob weights to the crankshaft that simulate the weight of the pistons and rods and also attach the harmonic balancer and the flexpate or flywheel. Now when they spin it up they will be balancing the entire rotating assembly that will be installed in the vehicle. /forums/images/graemlins/cool.gif
  11. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    If you take your engine to a shop to have it balanced and they don't ask for YOUR balancer, flexplate, and/or flywheel run and find another shop.
    John
