Need Help Now!!! Urgent(update...got it under control)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NEK5, Mar 6, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    alright so i`m probly havn some "newbie problems"...i am puttin in a throttle body spacer, and following the directions, i removed all the linkages,vac lines and other connections, and i got to removing the fuel lines...i did the one on the left(if your facing the front) and the one on the right looked like it was twisted...being alluminum i figured it was goin to crack takin it off and it didnt it probly wouldve putting it back on...and presto...it cracked....AND I HAVE NO IDEA WAT TO DO!!!
  2. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,620
    610
    Hooper, Utah 84315
    You have to get a new one:D
    It should have another fitting somewhere near the frame or so has to have a flex line in it some where cause the motor is rubber mounted so it has to be also. Just find where the connection is and disconnect it and either get a new one made or Checker might have a new one or the dealer. Hose and clamps will not work for long unless it built for it.
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    would autozone have it...there is no way that you can put some sort of extension????
  4. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    this is a pic of it
  5. kgblazerfive
    Dec 2, 2004
    10,620
    610
    Hooper, Utah 84315
    Zone might its only about a foot or so long at least the one is my van was. Climb under and pull it out should connect below the firewall near the frame, may have heat sheild on it above the exhaust.
  6. kgblazerfive
    Dec 2, 2004
    10,620
    610
    Hooper, Utah 84315
    If it wans't cracked you can usually bend them to fit but you cant fix the crack.
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    can u put a little section of fuel line with the proper fittings?
  8. kgblazerfive
    Dec 2, 2004
    10,620
    610
    Hooper, Utah 84315
    not unless it can handle the pressure which is in the 40 psi range it gets regulated to 6-10 at the injection unit but its alot more before that
  9. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    so do u have any part numbers and/or maybe some instructions on what to do????also which side is the return side????
  10. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    anyone.please???
  11. kgblazerfive
    Dec 2, 2004
    10,620
    610
    Hooper, Utah 84315
    Don't know any part number, on my van the lines went around the distributer then to a bracket that bolted to one of the bolts in the head then it turned into flex lines then attached to hard lines that ran back tho the fuel tank. I would just disconnect the lines from the TBI and then the hard lines and the bracket from the head. If my memory is correct they are two different sizes the smaller should be the return.
  12. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i believe they are both the same size
  13. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    okay...i got a fuel line repair kit and it already to go in....just gotta wait till tomorrow after school:/
