Need help on 383
Discussion in 'The Garage' started by NITRO, Jan 16, 2003.
  1. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i planned on sending my engine in and getting it machined, but first had some questions. first off, how much did u pay in machining costs? did u hafta buy n e other parts such as oil pan or n e thing else that will hafta b changed for it? do i use the stock con rods? hopefully i can take my time on this, but if not i might just hafta make this one into a 355 then start on the 383 when i get money/time. i really want one cause of the sheer power and torque. thanx for all the help.
    NITRO
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    IIRC I bought a rotating assembly for $899 (or $1099 with Hypereutectic pistons). Then I spent another $250 for machine work on the block to clearance the stroke - that was a great deal. Plus all the rest of the rebuild pieces there was more money for honing out .30 over. Mine only needed .20 but I couldn't find the pistons in this size.
    No other mods outside of the block and the rotating assembly.
    I understand the stock con-rods are good. Provided you don't plan on going above 5k rpms and they check out for spec and magna-flux. The bolt heads / nuts will need to be ground down for clearance.
    Good luck.
  3. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    You should use an oil pump drive shaft from a 400 and have the rod caps drilled and tapped to use bolts instead of nuts and bolts... You will also need to use a 400 Harmonic balancer and Flywheel too....
    John
  4. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    well, looks like the only machine shop that is even close to do this is in indy. plus its $2800 for them to completely do it. so i guess ill just go with a 355 and put about 10.5-11.5:1 pistons in it. thanx for the help
    NITRO /forums/images/graemlins/frown.gif
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    why not run a 6" rod 355? it would produce a very broad and flat torque curve.
  6. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    nitro, you running pump gas in that 11:1 engin? have you seen the engin kits at www.speedomotive.com? When i build the next one for the jimmy i going for the longest rods I can afford. 6" all the way!! long rod will help with the high compr too.
