Need help on a part time conversion
Discussion in 'The Garage' started by puckhead, Aug 16, 2006.
  1. puckhead
    puckhead 1/2 ton status
    Jun 17, 2005
    112
    colorado
    I have a 76 k20 camper special and I want to convert it to part time it has a 203 t case what parts do i need to complete this?
  2. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I got the MileMarker part time kit. It installed pretty easily and I have had no problems with it in the 5 years it's been in. Make sure you get selectable hubs too.
  3. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Take a look in the "Product Review" section. There's a great article on the part time kits. It's a pretty simple install.
  4. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
  5. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    what does a part time kit do?? sorrry for the youngin question
  6. Cricket
    Nov 29, 2004
    8,224
    Colorado
    The output shaft on a 203 has spyder gears just like a differential. The part time kit just replaces the spyders with solid metal blocks so the differential action is eliminated, making it part time 4x4 instead of fulltime.
  7. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    you can also get the full shaft kit. its a good bit more cash, but it makes the case stronger in the end and has less driveline play.
    after installation, you end up with the option of 2 low...VERY handy on the trails.
  8. Cricket
    Nov 29, 2004
    8,224
    Colorado
    The down side of the conversion is that oil is no longer slung to the rear output bearing constantly because you've made it a "PART TIME" t-case. Just remember to run it in 4 wheel drive with the front hubs unlocked for about 20 miles every 200. I just pop it in 4 high every time I fuel up and run it about 10 to 20 miles to keep the rear output lubricated.
  9. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    how do i know if i have a part-time 203?? it has manual hubs and when it is in 4-hi lok i can unlock the hubs
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    My '79 came with the cheeper PT option already installed. Those blocks put a huge load on a tiny needle thrust bearing and mine went away. Once it does that you'll hear a rythmic 'ge-ding, ge-ding, ge-ding" which is the locking part of the center diff trying to lock while moving. :eek1: :eek1:
    If you're going to keep the 203 I highly recommend springing for the more spendy conversion kit.
    Or you could "convert" it to part time by putting a doubler in there. :wink1: :wink1: :wink1:
