Need Help on Hard Brake Lines For 14 Bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Jul 19, 2001.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I need to get some new hard lines made for my brand new 1 ton 14 bolt to go from the drums to the center of the axle. Does anyone know what size fitting and what size tubing I need to get to have these things made? Any tips on fitting these things up? Thanks!
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  2. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    I went down to the local parts store and bought a two lengths of brake lines that already had the fitting on the end and just bent it to where I needed it. I was about $15. Just measure out the lenght that you need.
    73 3/4 ton Chevy. 383 stroker, TH350, NP 205, 14bolt FF(Detroit), Dana 44(limited Slip), 6in. lift, 36x 14.5 super swampers
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I think you need a different degree flange tool if you use stainless steel...
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  4. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    3/16 is pretty common size
  5. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    so does no one know the size? wes do you know? Thanks!
    Dawson
    Raleigh, NC
  6. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    3/16" is the size you'll need. They're the same size for 10bolts, 12bolts, 14s.....
    You can reuse yours on your truck if you want. I got mine from Inline tube. I went with the SS version. I got the double flare tool and I still couldn't flare the MOFO. So, I took it to a shop. Inline will flare em for you, but you need to the correct lenght. Maybe 16" to 20" on each side sounds about right. If you go with steel, you'll be able to flare em easy.
    Boss
    89' 1 TON of FUN K5
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, 3/16" is the correct size.
    Check out inlinetube.com.
    BTW, when flaring regular steel lines, they need to be 'double-flared.'
    The stainless steel lines need to be 'single-flared', because the metal is so much harder than the steel lines, if you tried 'double-flaring' a stainless line, you will have cracks more often than not. [​IMG]
    Anybody planning on checking out my homepage, forget it, I am still working on it!!!
  8. Boss
    2,550
    Maryland
    K30,
    Well, that just explains why I couldn't flare my SS line [​IMG]. I couldn't even crack the tube. I barely shaped it [​IMG] Should've known the single flare tool was the one to use....oh well, it's all good now though [​IMG].
    BOss
    89' 1 TON of FUN K5
  9. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    but its not regular 45 degree single flare, its something like a 37 degree single flare, you need a special stainless flare tool.
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Oh yeah, RaisedK5 is correct here!!! A different degree flare for the stainless too, cant use the same for the steel regular lines as the stainless!! Good eye Raised!! [​IMG]
    <font color=blue>Daddy told me while learning to pee......"if you shake it more than twice, then you are playing with it!!!"</font color=blue>
  11. michaelm
    Feb 2, 2001
    872
    wouldnt the flare have to match the fittings not the material the line is made of?
