NEED HELP on ID of a engine.
Discussion in 'The Garage' started by 89K1500Chevy, Jan 21, 2004.
  1. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    heres the Numbers i have pulled off the block. 3 GM - 3951509 - H 41 20 X the Heads have been steam vented like a 400ci small block and need to know what the engine is b/c im wanting to mabey keep it or build it up.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    block #3951509
    It could be one of 2 blocks:
    400SB.....70 - 71 4 bolt main
    400SB.....74 - 80 2 bolt main
  3. Dandwg
    Dandwg 1/2 ton status
    Feb 9, 2003
    190
    Turlock, California
    I tried looking in my LMC catalog, but I don't think it's helping.
    Sorry bud,I tried.
    /forums/images/graemlins/confused.gif
  4. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    should be a 70-73 2 bolt 400.
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    block #3951509
    Thats the number on my block... I think mine is a later 400. /forums/images/graemlins/thinking.gif
  6. dyeager535
    26,975
    What are the suffix codes if still present? Flat pad on the "deck" passenger side front. 2 or 3 digit code. (not the partial VIN)
  7. 89K1500Chevy
    Nov 9, 2002
    645
    I might be selling it for 150.00 I got it for 100 its got the heads, valve train , piston's, and cam missing the crank but it needs to be built up and idk how much it would end up costing me to build it up. Id love to have that in my 4x4 b/c it needs more. What do yall think?
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    509 is about the most common sbc 400 out there, alot like the 3970010 69-79 350 and 67 68 69 302 engines.
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    You would love having a built 400, trust me. /forums/images/graemlins/smile.gif I have around 2,600 to 2,700 bucks in my 406 but I replaced EVERYTHING that goes on the motor. It costs a little more to build a 400 over a 350 if you don't have the flex plate and harmonic balancer. You might be able to get away with a little less than I did if you reuse your existing carb and dist. I spent 300 for my long block core.
    $950 for all the machine work and engine kit
    $500 for rebuilt heads
    $100 for performer intake
    $350 for edel performer Q-jet
    $75 for used dist with different coil
    $70 for water pump
    $125 for 400 flexplate/balancer
    $125 air filter/vavle covers
    probably a few other things I can't remember
    I wan't AFR heads too along with a good set of headers.
    another $1,700 in the near future. Maybe the edel. pro flow EFI kit one day...$2,000
  10. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    That sounds like a plan....The AFR's with their well balanced intake/exhaust flows will compliment that single pattern cam even more /forums/images/graemlins/thumb.gif
  11. 89K1500Chevy
    Nov 9, 2002
    645
    Ok the guy that was going to get mine is looking for one that ends in 11 b/c it supposedly was over 300 hp stock? but idk anyways i guess i will be keeping it then.
    Well i have a tbi 350 so id like to try and reuse some form of it. I need to get a replacement TBI unit anyways b/c this one is leaky and not preforming anymore. Im thinking bout holly or edel.TBI unit its like 300 from summit.
    I really love this site you can get info so fast from here overnight and even in just a few hours Thanks everyone. /forums/images/graemlins/thumb.gif
  12. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    yeah, with AFR's, 1.6 rockers, headers, and MPFI I would be in the neighborhood of 425 to 450HP and well over 500ft pounds...
  13. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Im thinking bout holly or edel.TBI unit.
    [/ QUOTE ] You could get a used TPI system and have a new chip burned for it for around the same amount or less.
