Need Help on King Pin cover
Discussion in 'The Garage' started by DukeBoy88, Aug 14, 2004.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    I want to try the washer trick to see if it helps my death wobble. I have the four bolts of the cover removed and it doesn't want to come off. before I try to persuade it with a bigger hammer I wan't to check that I wasn't missing anything. thanks in advance.
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Just tap it to persuade it a bit. All that holds it are those 4 bolts.
  3. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    thanks, thats what I wanted to hear /forums/images/graemlins/thumb.gif
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    if the spring isn't shot it should release pretty easily with light taps. Long as you don't dent the thing up I say wack the [darn] out of it.
  5. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    three words; rubber dead blow!
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    If the spring is still any good it will jump off with a few light taps. If you crush it parts mike has them for around $8
