need help on my Travel Trailer... FRIDGE dont work
Discussion in 'The Lounge' started by uglychevyZZ4, May 17, 2003.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ok, i njeed help. the trailer we got for camping , well, the fridge is propane and elec. the fridge dont work on either. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif any suggestions?
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Bang it around a little, a freind of mine used to do that to his, worked every time. /forums/images/graemlins/eek.gif
  3. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Are the propane tanks full? /forums/images/graemlins/rotfl.gif
  4. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    When you use Electric does anything at all happen? Do you hear any noise at all? Or is it totally dead? There is a switch or knob that switches it from Propane to Electric. It can also have a neutral position. Check that. Also check your breakers.
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Sometimes on those gas type fridges the stuff in the lines gets in the wrong spots. You have to take it out and turn it upside down and let it sit like that for a while. Sounds crazy but it can work as a last resort.
  6. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    TRYED BANGING /forums/images/graemlins/angryfire.gif...didnt work /forums/images/graemlins/grin.gif
    has gas...
    upside down? /forums/images/graemlins/confused.gif
  7. landsmasher
    Mar 13, 2002
    4,423
    Ya turn it upside down for 24 hours and then right side up and let it sit for another 24 hours before you try it again. But that's only if it turns on, but doesn't get cold. Turning it upside down gets all the bubbles in the coolant out...
  8. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    My dad told me about the upside down trick before. We tried it on a propane fridge out of a trailer some years ago. Let it sit upside down for about a day or two, put it back, right side up, hooked it up, and it was cold inside within a couple hours. /forums/images/graemlins/thumb.gif
    Maybe not guaranteed to work, but worth a try if it's not working at all the way it is now.
  9. highwaydevil
    highwaydevil 1/2 ton status
    Oct 6, 2000
    145
    Colorado
    have you made sure there wasn't anything in the burner area? (Spider webs, etc.)
  10. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Have you taken the panel off on the outside of the trailer and taken a look at what your switches are doing? A lot of the time the switches inside the fridge can break and you have to light them manually from the outside of the trailer. I've owned a few different TTs and each one had it's own little fridge quirk.
  11. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    thats a problem, the outside has a tiny door, and cant see the burners and such really. /forums/images/graemlins/smirk.gif
