Need help on S15 Jimmy
Discussion in '1983-2005 S-Series models' started by jscott615, Mar 28, 2003.
  1. jscott615
    jscott615 Newbie
    Mar 27, 2003
    just bought '85 s15 jimmy w/ the 2.8 v6.......having trouble starting...aslo been stallin a little here and there and does not want to accelerate....i know these engines have little or no pick up at all but i have to put my foot to the floor to get the truck to go.....any suggestions on what the prob. might be?---thanx
  2. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    Heres a list for you-
    1. Is the air filter clean?
    2. The fuel filter probably needs to be replaced.
    3. You should check the sparkplugs to make sure none are too dirty
    4. If that doesn't fix it I would dump a bottle of carb. cleaner in the gas tank, then get a can of spray carb. cleaner and clean all the exterior linkages, the choke plate, and the throttle plate.
    hope this is helpful /forums/images/graemlins/thumb.gif
    Jeremy
  3. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    Check the usual items as listed, if you don't find anything, drop the exhaust and start it up, the catalytic convertor may be plugged, it will cause problems like you describe.
  4. jscott615
    jscott615 Newbie
    Mar 27, 2003
    today i replaced the air filter, spark plugs, fuel filter. and vacum lines----starts better now but still no improved acceleration---thanx for the help so far but does n e one have any other suggestions....thanx again
