Need help picking a cam
Discussion in 'The Garage' started by jace71, Apr 3, 2007.
  1. jace71
    jace71 Registered Member
    Mar 17, 2007
    32
    Georgia
    Looking to replace the cam in my 350 and would like some input on what you guys run. I don't want it to be too radical, just a nice lope to it at idle. Something that sounds good with headers and exhaust...thanks
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Your best bet is to call the tech line on any major cam manufacturer and give them the specs on your vehicle. They can narrow it down from there and tell you what your best option is for the type of driving you are going to do. Be prepared to know the vehicle weight, gear ratio, type of trans, converter stall speed, type of heads, compression ratio, etc. If it is an otherwise stock engine then just tell them what vehicle it is and they can go from there. This takes out all of the guess work and you end up with a better combo.
